    Sep 2005
    Finland
    Hi gurus
    Is there a way to encode / decode blackmagic 8 bit videos on linux (ffmpeg, mencoder, transcode, virtualdub via WiNe ... ??)
    Thansk advance
    -Jussi
  2. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    Do not see it available for Linux. Maybe download the windows version and try installing it with Wine. Not sure if that will work, but it's wortha shot.
    You can get the Blackmagic Codec from their website here
    http://www.decklink.com/support/software/
    HTH
    Roger
    There are many ways to measure success. You just have to find your own yardstick.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    it has been done on BOXX systems and at the THe Orphange" (i.e. Sin City)
    contact blackmagic -- it may be fairly simple to decode in fact -
