I have finally worked out how to produce a DVD from my AVI files and suddenly now started to develop a problem. I have a Panasonic NV GS250 camcorder, capture with Panasonic Motion DV Studio, edit with it, then encode with TMPGEnc, etc.
Since the weekend I am unable to use the Motion DV Studio programme, because when I open it, it opens and then the Windows error message opens and says HS Main.exe has encountered a problem and needs to close. I have uninstalled and reinstalled the programme twice, have run my virus scan, etc. This does not happen with other programmes on the computer. The only new thing that I have done on the computer is to download filters for Virtualdub, I do not know if that can have an effect.
Any advice please or can someone direct me to a site where I can get help.
Also check to see that the Panasonic software didn't change your audio settings on your computer...they don't call them Panachronics for nothing.
I use firewire. What audio settings,or where are the audio settings that I should check?
I just want to mention that I have been using the software for the past 3 months without a problem -
My computer is now in German and I forgot the English computer terminology....
Just make sure the sound card that came with your computer is still set as the default sound card....under system properties I believe. -
Can anyone please help or direct me to a site where someone can help me. I do not want to start all over finding new programmes to copy, edit etc
Need help with setting borders for track motion in Vegas Studio
By gtmb in forum EditingReplies: 1Last Post: 20th May 2011, 16:48 -
Panasonic ES25 dreaded U61 error message; fix?
By padraig in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Aug 2010, 15:54 -
Pinnacle Studio 12 frame rate error for Panasonic AVCHD Lite mts files
By dewispew in forum EditingReplies: 10Last Post: 13th Jul 2009, 03:13 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
