i dont know if this question has been asked before....
how do i remove the black bars from the top and bottom of a captured mpeg video?
The question begs: why? Your file wouldn't get appreciably smaller if you do.
i want the video to fill my computer/TV screen without the black bars...
The you will have to crop the bars off the top and bottom, and then crop the left and right ends off. Otherwise your computer will simply put bars there during playback to fill out the screen, or stretch and distort the image. What you are talking about is widecreen to 4:3 conversion. Is this really what you want ? You will actually end up with less image that if you leave the bars there.
Read my blog here.
yes, widescreen to 4:3 conversion, that is what I want to before i convert the mpegs to dvd. how do i do that? what software do i use? thanks.
You can just hit the ZOOM button on the DVD player. Problem solved, no work involved. Hopefully your player has this, most do.
virtualdub. Add a null transform filter so you can crop the video, then use the resize filter to resize it up to DVD spec. Frameserve the results to your mpeg encoder.
DVD Specs are found at the top of the lefthand menu.Read my blog here.
Crop/Remove black bars without re-encoding?
By agent154 in forum Blu-ray RippingReplies: 55Last Post: 22nd Aug 2015, 21:06 -
Can I remove black bars (top and bottom) when backing up my dvd's?
By jammiev in forum DVD RippingReplies: 10Last Post: 17th Jan 2012, 14:19 -
How to make ffdshow remove black bars by scaling?
By erik1958 in forum Software PlayingReplies: 2Last Post: 2nd Jun 2008, 04:16 -
Best tool to remove black bars?
By jedi34567 in forum Video ConversionReplies: 7Last Post: 15th Jan 2008, 11:44 -
[WMP11]- how to stretch the movie to remove the black bars?
By LuckY7 in forum Newbie / General discussionsReplies: 5Last Post: 26th Dec 2007, 13:44
