I am having a problem when I create a dvd with menus. I am using several mpeg files that I converted from avi. When I use DVD Composer to create a menu everything seems to work ok. I put the dvd in my dvd player and the menu looks great. The only problem is there is no sound on any of the episodes. When I create dthe menu I imported the same mpeg file for both audio and video. Should I make all of my mpegs mov and ac3 files?
Second, when I used TMPGEnc DVD Author everything once again looked like it was going to work ok. But when I put the dvd in my dvd player the menu doesn't show up. It shows big yellow boxes on my screen where the buttons should be. I click on one and it plays one of the episodes but once again there is no sound. Has anyone else experienced these problems?
Results 1 to 1 of 1
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 15:02 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 02:24 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
DVDComposer >> regonal settiing...
By 2Weights in forum Authoring (DVD)Replies: 8Last Post: 7th Nov 2007, 07:44 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
