To All,
A while back there was a thread concerning setting the layer break for DL disks using PGCEdit and DVDDecrypter. Unfortunately, I cannot seem to locate that specific thread.
My question regarding setting the layer break is:
1. If the disk is a full DL then it is obvious where the break should go. However,
2. If the disk is not a full DL, then should the break go at the max extent of layer 0 and then leaving a big section of layer 1 unused or should it go at the extent that is say 1/2 way of the movie? Thus, leaving a portion of layer 0 unused and approximately the same amount for layer 1 or
3. Most likely put the break at some point that is convient with respect to the movie. regardless of the remainder of layer 0 and 1. If this is the answer, then how does one convert running time in the movie to sector address on the disk. Which is what I think is needed in order to specify a layer break position?
Any help or guidance is greatly appreciated.
This guide should help you. "STEP 7 – SETTING THE LAYER BREAK" is the part you're interested in.
VegasBud,
Thanks. I think that is exactly what is needed. I will play with it tonight and get back if there are any problems.
Once again, thanks.
Ed
PGCEdit and ImgBurn disagree on Layer Break
By koberulz in forum Authoring (DVD)Replies: 8Last Post: 2nd Mar 2012, 12:45 -
DVD-9 Layer Break Question (PGCedit)
By sdsumike619 in forum Authoring (DVD)Replies: 8Last Post: 22nd Jan 2010, 18:19 -
Using PGCedit to remove layer break(s)
By sdsumike619 in forum Authoring (DVD)Replies: 22Last Post: 10th Jul 2009, 17:17 -
Img Burn Layer Break Setting
By anfield7 in forum Newbie / General discussionsReplies: 4Last Post: 5th Mar 2009, 09:48 -
Setting the layer break on a DVD9 (DVDLab Pro project)
By lorix in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2008, 11:19
