Does anyone know of a simple little program out there that will be able to analyze a .VOB file to tell me if it's in NTSC of PAL format?
The reason I ask is, I am converting PAL .VOBs to NTSC using VOB Blanker. I want to make sure the output is really in NTSC format.
THANKS !!!!!
Chris
The big giveaway is the size of the frame. PAL will be 576 lines (720x576) NTSC will be 480 lines (720x480). Just load the VOB into VirtualDub and look at the size. Put in a "null" filter to see the size.
Darryl
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
program to analyze and display video file specs?
By dog food in forum Newbie / General discussionsReplies: 4Last Post: 2nd Feb 2011, 08:25 -
60fps versus 50fps? PAL or NTSC in AVCHD?? need advice!
By ftitus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th Nov 2010, 07:11 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC - 29.97 versus 30 fps?
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2007, 11:27
