A few years ago I installed AVIC (fourCC Changer) and was able to change .avi files that were XviD to DivX. A few weeks ago I had a fairly major computer meltdown, but I was able to get it fixed and had to reinstall quite a few things. My problem now is that the AVIC program no longer displays an option to turn an XviD to DivX. What it does give me is the option to convert the file into either MP41, MP42, MP43 or DIV3. Am I missing something here? I have opened a few .avi files that are XviD encoded and when I do, I can convert it to "XviD", but that's pointless. Any suggestions?
Do you hav DivX installed on your system ??
Who is watching the watchers. -
Type it manually. Why would you want to change the fourCC anyway? If you really want to, it is probably easier to set it in the XviD config before you encode or use DivX for encoding.
Originally Posted by nzjacob
Originally Posted by celtic_druid
You may use DVdate to change the FourCC of an AVI file. No need to have the codecs installed. It's only a change in the header of the avi-file without recompression. It is indeed useful for playing the file in some stand-alone player.
Paul Glagla
http://paul.glagla.free.fr/index_en.htm -
Only ever heard of a couple of Sony players that don't support XviD's fourCC and on some of them XVID support was added via a firmware update.
Shouldn't be possible to ruin a file that way. As pointed out all it is doing is changing a couple of bytes in the header. If it didn't play then I guess you typed it in wrong. Wrong fourCC means that no decoder will recognise it and fourCC's are case sensitive. -
I used it on 2 files last night and it changed it perfectly. However...I did encounter an error message (something about "pins"), but since I'm posting this at work, I can't give you the exact error. Despite the error message, the program did what I needed it to do. Thanks!!
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
AVI to DVD fourCC xvid question
By rockonvidtrade in forum Authoring (DVD)Replies: 7Last Post: 23rd Feb 2009, 11:29 -
FOURCC Change
By anirban in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2008, 20:35 -
Divx 3 AVI files for my Pioneer AVIC D3
By cbeausoleil in forum MacReplies: 5Last Post: 19th Aug 2008, 22:59 -
Bad fourcc?
By louv68 in forum Video ConversionReplies: 1Last Post: 12th Mar 2008, 23:04
