I keep getting this error:
**ERROR: [mplex] MUX STATUS: Frame data under-runs detected!
when trying to encode with subtitles-are there any obvious places to start looking to solve this?
okay–I haven't done it the same way this time. The last time I tried making an mpeg from an AVI then subtitling it. This time I tried doing both at once. I've tried both methods a couple of times now-all un-sucessfully...
Encoding started on Wed Mar 29 15:23:23 PST 2006
/Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi.ff/
-f 2 -b 1840 -B 260 -V 46 -a 1
-F 3
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
MPlayer dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
Using Unoptimized OnScreenDisplay
Using Darwin accurate timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/Users/papa/.mplayer/input.conf'
Parsing input config file /Users/papa/.mplayer/input.conf
Input config file /Users/papa/.mplayer/input.conf parsed: 2 binds
get_path('Paradise.Now.cd1.avi.conf') -> '/Users/papa/.mplayer/Paradise.Now.cd1.avi.conf'
Playing /Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi.
get_path('sub/') -> '/Users/papa/.mplayer/sub/'
[file] File size is 466794066 bytes
STREAM: [file] /Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi
STREAM: Description: File
STREAM: Author: Albeu
STREAM: Comment: based on the code from ??? (probably Arpi)
AVI file format detected.
list_end=0x162
======= AVI Header =======
us/frame: 40000 (fps=25.000)
max bytes/sec: 0
padding: 0
MainAVIHeader.dwFlags: (16) HAS_INDEX
frames total: 69733 initial: 0
streams: 2
Suggested BufferSize: 0
Size: 640 x 256
list_end=0xE2
==> Found video stream: 0
====== STREAM Header =====
Type: sdiv FCC: XVID (58564944)
Flags: 0
Priority: 0 Language: 0
InitialFrames: 1
Rate: 25000/1000 = 25.000
Start: 0 Len: 69733
Suggested BufferSize: 89613
Quality 0
Sample size: 0
Found 'bih', 40 bytes of 40
======= VIDEO Format ======
biSize 40
biWidth 640
biHeight 256
biPlanes 1
biBitCount 24
biCompression 808802372='05XD'
biSizeImage 2488320
Regenerating keyframe table for MPEG4 video
list_end=0x162
==> Found audio stream: 1
Type: sdua FCC: (0)
Flags: 0
InitialFrames: 1
Rate: 44100/1152 = 38.281
Start: 0 Len: 106770
Suggested BufferSize: 731
Quality 0
Sample size: 0
Found 'wf', 30 bytes of 18
======= WAVE Format =======
Format Tag: 85 (0x55)
Channels: 2
Samplerate: 44100
avg byte/sec: 16000
Block align: 1152
bits/sample: 0
cbSize: 12
mp3.wID=256
mp3.fdwFlags=0x0
mp3.nBlockSize=41217
mp3.nFramesPerBlock=256
mp3.nCodecDelay=0
list_end=0x1BA79EDA
Found movie at 0x200C - 0x1BA79EDA
Reading INDEX block, 176503 chunks for 69733 frames (fpos=0x0)
AVI index offset: 0x2008 (movi=0x200C idx0=0x4 idx1=0x112)
Auto-selected AVI audio ID = 1
Auto-selected AVI video ID = 0
AVI: Searching for audio stream (id:1)
AVI video size=417236117 (69733) audio size=45204011 (106770)
VIDEO: [DX50] 640x256 24bpp 25.000 fps 1196.7 kbps (146.1 kbyte/s)
[V] filefmt:3 fourcc:0x30355844 size:640x256 fps:25.00 ftime:=0.0400
SUB: Detected subtitle file format: subviewer
SUB: opened iconv descriptor.
SUB: closed iconv descriptor.
SUB: Read 489 subtitles.
SUB: added subtitle file (1): /Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.srt
SUB: added subtitle file (2): /Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.srt
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
dec_audio: Allocating 4608 + 65536 = 70144 bytes for output buffer.
mp3lib: using generic C decore!
MP3lib: init layer2&3 finished, tables done
MPEG 1.0, Layer III, 44100 Hz 80 kbit Joint-Stereo, BPF: 261
Channels: 2, copyright: No, original: No, CRC: No, emphasis: 0
AUDIO: 44100 Hz, 2 ch, s16be, 80.0 kbit/5.67% (ratio: 10000->176400)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
Using (default) progressive frame mode.============================================= =============================
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
INFO: libavcodec init OK!
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
Building audio filter chain for 44100Hz/2ch/s16be -> 0Hz/0ch/s8...
[libaf] Adding filter dummy
[dummy] Was reinitialized: 44100Hz/2ch/s16be
[AO PCM] File: audiodump.wav (WAVE)
PCM: Samplerate: 44100Hz Channels: Stereo Format s16le
[AO PCM] Info: Faster dumping is achieved with -vc null -vo null
PCM: Info: to write WAVE files use -ao pcm:waveheader (default).
AO: [pcm] 44100Hz 2ch s16le (2 bytes per sample)
AO: Description: RAW PCM/WAVE file writer audio output
AO: Author: Atmosfear
Building audio filter chain for 44100Hz/2ch/s16be -> 44100Hz/2ch/s16le...
[libaf] Adding filter format
[format] Changing sample format from big-endian 16-bit signed int to little-endian 16-bit signed int
[format] Accelerated endianess conversion only
Starting playback...
[libaf] Reallocating memory in module format, old len = 0, new len = 65540
[ffmpeg] aspect_ratio: 2.500000
VDec: vo config request - 640 x 256 (preferred colorspace: Planar YV12)
Trying filter chain: vo
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 2.50:1 - prescaling to correct movie aspect.
VO Config (640x256->640x256,flags=0,'MPlayer',0x32315659)
VO: [yuv4mpeg] 640x256 => 640x256 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools
VO: Author: Robert Kesterson <robertk@robertk.com>
INFO: [yuvscaler] VCD output format requested in PAL/SECAM norm
0 bytes
INFO: [yuvscaler] input: frame size: 640x256 pixels (245760 bytes)
INFO: [yuvscaler] input: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: ?
INFO: [yuvscaler] from 640x256, take 640x256+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 640x192, 640x256 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] black lines: 32 above and 32 under
INFO: [yuvscaler] black columns: 0 left and 0 right
INFO: [yuvscaler] frame rate: 25.000 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 4 to 3 for height
INFO: [yuvscaler] Specific downscaling routing number 7
INFO: [yuvscaler] output: frame size: 640x256 pixels (245760 bytes)
INFO: [yuvscaler] output: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?
INFO: [mpeg2enc] Selecting VCD output profile
INFO: [mpeg2enc] Assuming norm PAL
INFO: [mpeg2enc] Encoding MPEG-1 video to /Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi.ff.mpv
INFO: [mpeg2enc] Horizontal size: 640 pel
INFO: [mpeg2enc] Aspect ratio code: 1 = 1:1 (square pixels)
INFO: [mpeg2enc] Frame rate code: 3 = 25.0 (PAL/SECAM VIDEO / converted FILM)
INFO: [mpeg2enc] Bitrate: 1840 KBit/s
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 12 TO 12
INFO: [mpeg2enc] Setting colour/gamma parameters to "PAL B/G"
XXX initial v_pts=0.000 a_pos=7246 (0.453)
*** [vo] Allocating (slices) mp_image_t, 640x256x12bpp YUV planar, 245760 bytes
NFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] size - setting constrained_parameters_flag = 0
INFO: [mpeg2enc] mpeg1 - setting intra_dc_precision = 0
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 33 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
Unicode font: 242 glyphs.
end 20046 P quant=5.46 total act=2967189.4
0 0
er 42334
3
d 64176 I quant=10.82 total act=9200435.2
ds_fill_buffer: EOF reached (stream: audio)
ds_fill_buffer: EOF reached (stream: video)
EOF code: 1
Uninit audio filters...
[libaf] Removing filter dummy
[libaf] Removing filter format
uninit audio: mp3lib
uninit video: ffmpeg
INFO: [yuvscaler] End of stream!
Exiting... (End of file)
INFO: [yuvscaler] Normal exit: end of stream with frame number 69734!
INFO: [mpeg2enc] Guesstimated final muxed size = 732207000
wait, encoding to mp2 audio with mp2enc...
INFO: Opened WAV file, freq = 44100 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 491996160 bytes
INFO: slots/frame = 731
INFO: frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
INFO: Fractional number of slots, padding required
INFO: System is big endian
INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi.ff.mpa"
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi.ff.mpv looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi.ff.mpa looks like an MPEG Audio stream.
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting VCD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi.ff.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 640
INFO: [mplex] Frame height : 256
INFO: [mplex] Aspect ratio : 1:1 (square pixels)
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 1840000 bits/sec
INFO: [mplex] Vbv buffer size : 63488 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/CHATHOMME/MUSIC/FILMS/PARADISE/Paradise.Now.cd1.avi.ff.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2101648
INFO: [mplex] Setting best-guess data rate.
INFO: [mplex] Run-in Sectors = 43 Video delay = 34648 Audio delay = 38248
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 114688 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Padding : sector=00000000
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=15266879 required(DTS)=15266832
++ WARN: [mplex] Video e0: buf= 89966 frame=004225 sector=00016387
++ WARN: [mplex] Audio c0: buf= 3041 frame=006468 sector=00002076
++ WARN: [mplex] Padding : sector=00000452
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=15526337 required(DTS)=15526032
++ WARN: [mplex] Video e0: buf= 90024 frame=004296 sector=00016674
++ WARN: [mplex] Audio c0: buf= 3733 frame=006577 sector=00002111
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=15785794 required(DTS)=15785232
++ WARN: [mplex] Video e0: buf= 93929 frame=004368 sector=00016960
++ WARN: [mplex] Audio c0: buf= 2146 frame=006689 sector=00002147
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=16044445 required(DTS)=16044432
++ WARN: [mplex] Video e0: buf= 97324 frame=004440 sector=00017246
++ WARN: [mplex] Audio c0: buf= 2838 frame=006798 sector=00002182
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=16286176 required(DTS)=16285632
++ WARN: [mplex] Video e0: buf= 107499 frame=004508 sector=00017513
++ WARN: [mplex] Audio c0: buf= 2968 frame=006901 sector=00002215
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=16527906 required(DTS)=16523232
++ WARN: [mplex] Video e0: buf= 112387 frame=004574 sector=00017781
++ WARN: [mplex] Audio c0: buf= 4096 frame=007001 sector=00002247
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=16769636 required(DTS)=16768032
++ WARN: [mplex] Video e0: buf= 112383 frame=004641 sector=00018047
++ WARN: [mplex] Audio c0: buf= 3228 frame=007107 sector=00002281
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=17011366 required(DTS)=17005632
++ WARN: [mplex] Video e0: buf= 112383 frame=004707 sector=00018314
++ WARN: [mplex] Audio c0: buf= 3359 frame=007210 sector=00002314
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=17253097 required(DTS)=17250432
++ WARN: [mplex] Video e0: buf= 112392 frame=004776 sector=00018581
++ WARN: [mplex] Audio c0: buf= 2757 frame=007312 sector=00002347
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=17494827 required(DTS)=17488032
++ WARN: [mplex] Video e0: buf= 112392 frame=004842 sector=00018849
++ WARN: [mplex] Audio c0: buf= 4096 frame=007412 sector=00002379
++ WARN: [mplex] Stream e0: data will arrive too late sent(SCR)=17736557 required(DTS)=17729232
++ WARN: [mplex] Video e0: buf= 112383 frame=004908 sector=00019116
++ WARN: [mplex] Audio c0: buf= 4096 frame=007515 sector=00002412
**ERROR: [mplex] Too many frame drops -exiting
It seems you want to create a VCD, but you use an incorrect size of 640x256, which is not VCD compliant. So do it again and make sure to follow these steps in this exact order: 1. Open source file in ffmpegX. 2. Select VCD target in the Summary tab. 3. Click Encode.
Need Help about Professional Subtitling
By kei_siuip in forum SubtitleReplies: 1Last Post: 14th Mar 2011, 03:04 -
Subtitling on the Mac
By sky captain in forum MacReplies: 2Last Post: 12th Jan 2010, 13:16 -
Subtitling only distinct parts
By zuja9 in forum SubtitleReplies: 3Last Post: 28th Sep 2009, 08:10 -
mkv subtitling
By eliqush in forum EditingReplies: 6Last Post: 19th Jun 2009, 03:11 -
Subtitling. Thanks in advance.
By shr3dd3r in forum SubtitleReplies: 4Last Post: 11th Sep 2007, 14:21
