I have a .sub file demuxed from an OGM file. When I import it into DVD-Lab pro's subtitle thingy, it generates a substream without errors. When i compile the DVD, there's at least one spot where the subtitles don't appear. I've checked the .sub file and it seems all right. The subtitles for the timecode where they are missing are in the sub file, and in the pre-rendered part of DVD-lab pro (before it generates an sp1 stream).
EDIT: The problem seems to be eliminated when I use non-drop frame (30 fps) instead of drop frame (29.97). However, this makes all the subtitles appear a split second later than they should.
EDIT EDIT: I think I've found the problem, the subtitles were timed for the original frame rate of 23.97, and the video was re-encoded for 29.97. I used Subtitle Workshop to convert the subtitles to 29.97 and they all show up fine now.
Results 1 to 1 of 1
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42 -
DVD-Lab Pro Subtitles Encoding troubles
By laste in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2011, 15:12 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
out of sync subtitles - DVD Lab Pro
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 16:57
