I am getting this error when I try to go to into the Preferences and Settings in SVCD2DVD 2.1 I have registered and I have installed the latest download and rebooted but I keep getting this error.
"An unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will shut down immediately.
NeroAPI was not initialized or was unsuccessfully initialized! Make sure that all relevant properties are filled in. Check " LastError" property for possible errors."
This happens every time that I try to go to Preferences and Settings on the SVCD2DVD 2.1 Menu bar.
If I understand correctly I should be able to go into this and change to two pass encoding.
Thank You
Results 1 to 18 of 18
Do you have Nero installed and if so what build?
I'm getting the same error i have nero burning rom 6 version 6.6.0.6
Thanks in advanceD-block two gunz up!!!!!!!!! -
The latest Nero v6 build is 6.6.1.4. Can you update to that to see if it solves the issue?
http://www.nero.com/nero6/eng/nero-up.phpSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Good news.Originally Posted by Jadakiss
For everyone else:
Thats the version i have and SVCD2DVD v2.1 was built against that and it is confirmed that it works with this version and above (i.e. v7+).SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I was not that excited to install Nero 6.x. I have CopyToDVD, DVD Decrypter, ImgBurn, and Sonic Record Now! Deluxe installed. Have had installed Nero in the past with these applications and they did not appear to get along. So far so good after the install of Nero. SVCD2DVD appears to be working now have not used SVCD2DVD to it's fullest extend yet.
The problem is/was that I could not get into the Preferences and Settings without getting this error, NeroAPI was not initialized. Now that I installed Nero 6.x I am able to get into Preferences and Settings and change the burning software used. Otherwise I was unable to get into Preferences and Settings without Nero 6.x installed.
ok. Well CopyToDVD, DVD Decrypter, ImgBurn can be used too. My guess is that because you had Nero on your PC S2D thought it was installed properly (which was not as you uninstalled it).
Never had Nero installed on the machine that I had installed S2D on, so it was looking for something that was not there. I did have Nero CD-Speed installed but not Nero 6.x until I ran into this little glitch. S2D runs great now and that is what I was looking for.
Mmm. Maybe "Nero CD-Speed" gave the impression that Nero was installed....
Anyway: glad your up & running.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I don't have any Nero software installed whatsoever, and I get this same problem. I do not WANT to install Nero to get S2D to work...it shouldn't be necessary. What options do we have? Is there some sort of registry setting to allow the Preferences option to be useable. As it is S2D is not very useful, especially if you want to use it primarily for the conversion options and not the DVD burning itself.
ok. I will trap the error.... Do you get any further exception details?
i just instales the newest update to svcd2dvd and i am getting this error is there away around this with out using nero thanks.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidCastException: QueryInterface for interface NEROLib.INero5 failed.
at NEROLib.NeroClass.GetDrives(NERO_MEDIA_TYPE lVal)
at x3284ccece41ee22b.x753c147d603aabe6.x12fd49dfa62a3 ecf()
at x3284ccece41ee22b.x753c147d603aabe6.get_xaa807afed 8dd2568()
at x3284ccece41ee22b.x58ff75059d7bf794..ctor()
at x3284ccece41ee22b.x210ff09a2516b1a7.x6341f549d2d05 feb(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.DotNetBarManager.IN(BaseIt em 5DO)
at DevComponents.DotNetBar.BaseItem.RaiseClick()
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.GenericItemContainer.Inter nalMouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.Bar.OnMouseUp(MouseEventAr gs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.Bar.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.1.2284.26117
Win32 Version: 2.1.2284.26117
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 5.6.0.0
Win32 Version: 5.6.1.9
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
Interop.NEROLib
Assembly Version: 1.4.0.0
Win32 Version: 1.4.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.NEROLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog. -
You have Nero installed right?
How do you burn initialized DVD discs?
By Djard in forum MediaReplies: 6Last Post: 24th Jul 2011, 13:26
