All of a sudden avi=>mpg conversion using TMPGEnc stopped picking up and embedding .srt subtitles.
I tried the usual fixes of checking VFapi prority settings and reinstalling VobSub. No joy. Searching around
the most recent change I made was uninstalling SVCD2DVD 2.0 and installing 2.1. I'm wordering if maybe
some subtitle support could be interfering with VobSub? I tried installing latest VSFilter also and with that installed, TMPGEnc displays the green arrow in the tray and takes forever to load.
Has anyone else noticed VobSub breaking or acting weird after SVCD2DVD 2.1 install?
I can't see it. SVCD2DVD doesn't use/install any codecs or any directshow filters etc... Uninstall v2.1 and see if that makes a difference...
Please do. TIA
I found the issue. Somehow or other DirectVobSub configuration got changed from
"load when needed" to "never load".
I don't know how that happened but I'm glad it's an easy fix.
Sorry to bother you over nuthin'.
problem with VobSub
By nazim in forum SubtitleReplies: 4Last Post: 23rd Jun 2011, 16:32 -
Vobsub
By leftspeaker2000 in forum SubtitleReplies: 0Last Post: 31st May 2011, 11:41 -
Problem with vobsub 2.23
By mop59136 in forum SubtitleReplies: 2Last Post: 8th Mar 2011, 12:07 -
Vobsub (or just sup??) for HDPlayer
By qknet in forum SubtitleReplies: 5Last Post: 28th Dec 2010, 19:38 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 13:27
