Is ther a special way to burn a 90 min cd-r...
What software can do it and how ?
thanks,
ofir
Results 1 to 12 of 12
In order to burn a 90min CDR your CDRW drive itself must support it! and once you do, you can burn any 90min CD media.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Safe Hi,
thanks for your anser,
( my name is ofir and i'm from israel )
how can i tell if my cd-r driver can write a 90 min cd-r ???
thanks,
ofir
Hi Ofir, which CDRW drive do you have ? you could check the list of CDReWriters posted on VCDhelp which i've made, it will tell you which drives support 90/99min media.
Best Regards,
Sefy Levy,
Safe hi,
I can't fint you CD-ReWriters list...
I have Yamaha 8x4x24 cd-rw drive ( i can't remember is model ) and pioner 525 dvd player.
1. can i write a 90 min cd-r and read it on my dvd player ???
2. in what software ???
thanks,
ofir
24x8x4, hmmm, my guess is that you can NOT burn 90 minute media, your drive sounds rather old, my drive is 24x4x4 and it doesnt support 90 minute. Either way, dont quote me, you should check up on it.
I'm afraid your CDRW is too old and does not support 90min CDRs
You can buy in Plonter the Lite-On 24x10x40 for 117$ and it supports upto 99min CDR media.
Best Regards,
Sefy Levy,
That's complete crap about drives being too old. I purchased my Teac CD-R55S in 1998 and it burns 99 minute CDs without a problem, Data, Audio and Video. A friends Iomega USB recorder is about 2 years newer than mine and it does not support 99 minute cds.
You really want to know if your drive can support these discs, go tot the http://www.nero.com site, check the drive compatibility list and see if you drive supports overburning.
Or if you have a newer version of Nero already installed, got to the 'Recorder' menu item and select 'Choose Recorder'. In there it will tell you if overburning is supported.
Have fun. -
bosss7, it's not all that crap, it depends more on the manufacturer itself, not all old drives support 90/99, and the same goes for new drives as well.
Best Regards,
Sefy Levy,
Isn't it so that 80 minute CD-Rs are also "overburned". By now it would seem strange, though, if a CD-burner would not burn a 80-min CD-R. Nevertheless. First of all. Nero's list is not completely reliable. My Philips PCRW1208 supports overburning and the list says, it doesn't.
One tip: If you can get a hold of a small pack of 90-min discs (like 10 or so, here I can just buy in 50 and 100s) then buy it and try it. But first of all. Upgrade your burning software and your burner's firmware to the latest versions. It might help.
But one thing is for sure. It is very unlikely that your DVD Player will support a disc that is burned with over 90 minutes of data. A good thing, tho. You can still burn 85 minutes on a 90 minute CD-R. It increases the chances that your DVD player plays them to the end and also that your bunrer manages to burn them.
85 minutes are still better than 80, isn't that so?
Hope that helped. -
Actually when the CD standard was formed, the 80min is well in spec, but was not used till recenet years, but it is in the official standard
The 90/99min is somewhat of an overstretch of the standard which is why not many is capable of it.
Best Regards,
Sefy Levy,
My recorder doesnt support overburning, and if burning 90 minute CDR's is overburning, then i am glad to stay away from it, during the process of overburning, you run the risk ( a minute risk, but still a risk ) of permanantly ******* up your drive lens, it is documented somewhere, who knows where but
Why does it only convert 15 min. worth?
By woodcliff in forum ffmpegX general discussionReplies: 1Last Post: 12th Dec 2009, 20:11 -
Last few min of AVI being cropped out
By Mr_Del in forum Video ConversionReplies: 1Last Post: 15th Mar 2009, 08:59 -
4 min movie conversion
By Tahir Ramzan in forum Video ConversionReplies: 2Last Post: 3rd Jan 2009, 00:46 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48 -
Replaying a 10 min section
By elute96 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 14:03
