Does anyone know how I can blow up an avi file an have it keep its clearity thanks
Results 1 to 16 of 16
usually when you blow something up it's usually in too many pieces for clarity to become an issue.
In the real world the answer is no! In the world of make believe, yes!
Please give more details.bits -
I have an avi file that my security cameras made and when I make them full screen they are blurry I need to clean it up some when its fullscreen or enlarged. thanks for the help
Capture the file in a larger format. Stretching and skewing an image will always produce blurry or pixelated results.
I understand that but that dont help me with what I have, so your saying there is nothing out there that I can use to enlarge my video and make it still be clear?
Nothing that I know of. You must capture the image in a better format or your must capture an image in a larger image size in order to bring it full screen without lossing clarity.
Does your security camera software offer you the option to record in a different format(MPG or other)? Can you change the capture size?
You could drop it into VirtualDub and apply some filters from http://neuron2.net/
I second what redwudz has to say - you've nothing to lose by trying it anyways, right?
Best of luck!
TTWC"I've got a present for ya!" - TTWC -
He's been watching too much tv. You just can't realistically enlarge low resolution to make it clearer, no matter what CSI or Law & Order depict.
TANSTAAFL -
Yep, like blowing up one of the above avitars to make it a desktop wallpaper and expecting it to retain detail. Except in the case of video you have to do it for 25fps or whatever.
Best you can do is try some sharpening filters and use a decent resize filter. -
Those old security cam resolutions of 10 years ago couldn't even show the license plate
Since it is a security camera my suggestion remains to capture your footage at a larger frame. It will take up more space but you will have better clarity or at least a larger image.
Blowing-up letterbox
By carlmart in forum Video ConversionReplies: 13Last Post: 1st May 2012, 15:56 -
Blowing 4:3 cropped video to 16:9
By carlmart in forum Video ConversionReplies: 4Last Post: 1st Jun 2011, 10:40 -
Windows 8 to be "mind blowing"
By deadrats in forum ComputerReplies: 2Last Post: 12th Feb 2010, 15:10 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
500GB seagate drive at bestbuy (I'm blowing off some steam here......)
By Webster in forum Off topicReplies: 20Last Post: 8th Oct 2007, 13:16
