I dunno about the CD-RW's, but I use Memorex 80-min. CDR's exclusively on my TDK VeloCD writer with absolutely no problems whatsoever...
The discs I make for others all work fine in their machines as well...
When you all say they suck, are you only speaking of the RW's??? I don't use RW discs, only the CDR's...I like the top white coating they use for the label side...tough to scratch off, unlike silver-topped cd's...
Every time I buy new CDRW's I have to use the FULL ERASE method in Nero, not the quick method. The quick method only blanks the TOC track. I have used Memorex 74 min CDRW's withouth any problems. Try to fully erase the CDRW first, I think it takes 20 minutes for the full erase, and ~1 minute for the quick erase.
Can firmware stop my rewriter from working with cdrw disks, I have upgraded to 1.0j (Yamaha4416e)
The only time you FORMAT a CDRW is to use it with Direct CD.
You should select ERASE if you want to reuse a CDRW for VCD or audio.
can't format new disks
By jesse br in forum DVD RippingReplies: 3Last Post: 21st Nov 2010, 11:57 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Pana ES15 won't format disks but plays/records OK
By John32118 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 7th Oct 2009, 20:54 -
Disks - File Format - Best Ones to use
By TamtheMan in forum Newbie / General discussionsReplies: 16Last Post: 5th Dec 2007, 11:44 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
