i get this error (pic above) when i open DVD files sometimes (not all the time). at first, i thought it was the encoders i was using (ConvertXtoDVD and WinAVI) but ive tried converting other files to DVD with these programs and TDA opens the output DVD files from these programs most of the time.
anyone know why this error comes up and how to avoid it?
It is because of your converters - certainly ConvertXtoDVD can produce this error from time to time - and the solution is pretty simple. Delete the IFO and BUP files, then open the vobs in IFOEdit and create new ones. TDA will them open your video.
Read my blog here.
sweet, thanks. worked like a charm.
edit: ok, now i have another problem. it only creates IFO/BUP's for the VTS selected. how do i create VOB/BUP's for the entire DVD? -
well i tried processing each VTS title seperately, but it just replaces the IFO/BUP files in there when i do the next VTS title. i tried doing them in seperate folders, but that doesnt work either. im trying to open them with TMPGEnc DVD author... the first one opens fine, but the other dont work.
ok, i got it finally. i had to process them in seperate folders, and rename the VOB files because IFOEdit didnt match the IFO/BUP files with the same name as the VOB files. for example, for VTS_02_1.VOB/VTS_02_2.VOB, IFOEdit made the IFO/BUP files VTS_01_1.bup/ifo, so i renamed the VOB files to 01_1/01_2
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 01:31 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author 1.5 Problem... Only with these files... Weird, Help!
By acid_burn in forum Authoring (DVD)Replies: 3Last Post: 11th Jun 2008, 13:50 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
