    Feb 2006
    hello all i would like to take screenshots of a video in quicktime so i can make parts of it into gif, the vido is a .rm file type does anyone know how i can get the file to play in quciktime, or a program thats will allow me to take screenshots of each frame so can send them to my photoshop?
    Dec 2004
    Australia
    Not aware of any rm quick time plugins. Try Media Player Classic or mplayer.
    Feb 2006
    well i was able to skip 1 frame at a time, but i can take a screen shot of it, do you know if theres a option on the player (or another player) that can disable video aceleration?
    Feb 2006
    nm i found the save image option
    it keeps going back to the frame i puase on after each snapshot
    Dec 2004
    Australia
    You could use AVISynth to open it in VDubMod, then save out all frames as images. I'd still probably go with mplayer, it can actually output directly to animated gif.
    Feb 2006
    i cant figure out where to download the mplayer from, I got dizzy hoping back in forth.
    Dec 2004
    Australia
    Well you can find my windows compiles at: http://celticdruid.no-ip.com/xvid/
    mplayer.exe -vo help for a list of outputs. png or tga I guess if you want images to convert or gif89a for an animate gif. You also need to add -vf scale since image output requires RGB. Also -ao null if you don't want to listen to the audio.
    Oh yeah for some rm formats you need the rm dll's from the mplayer site.
  8. Mod Neophyte redwudz's Avatar
    USA
    LazerAce7, Please modify your signature size to conform to our rules. See https://forum.videohelp.com/viewtopic.php?t=124514 and scroll down to 'Signatures'.
    Moderator redwudz
