Can someone suggest likely reasons why the DVD-RW discs I've been making recently are taking over a minute to get recognised by my DVD player please? When I load commercial ones, and those I made myself with DVD-RW some months ago, the player used to bring up the main menu in a few seconds after the tray closed.
Also, even when it does start (after over a minute), the DVD starts playing immediately, without going to the menu.
This has happened with authoring/burning by at least two different methods. The latest is with TDA.
Terry, West Sussex, UK
There are many variables...most of which you will never find a clear answer on. Why does my player like +RW discs....but not +RW discs that have been bitset to ROM?
In your case it just may be a simple media issue...it doesn't like that brand maybe.
Media Player Classic suddenly extremely slow menu
By brucend75 in forum Software PlayingReplies: 6Last Post: 30th Dec 2011, 22:56 -
NTSC DVD player that allows you to slow down playback speed?
By eurotimes2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 31st Aug 2011, 01:46 -
Converted mkv has extremely slow audio
By PandaShake in forum Video ConversionReplies: 5Last Post: 4th Jul 2009, 04:15 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 14:11 -
Xvid encoding going extremely slow..
By daking in forum DVD RippingReplies: 11Last Post: 11th Jun 2007, 11:27
