What's the easiest way to convert a small RealMedia .rm movie file to a quicktime player compatible format?
Thanks in advance!
Dante
LOL!
he said "easiest".
unfortunately, my friend, that is not often the case.
the "easiest" I found was to use Snapz Pro X, and
capture the footage as it played in Real Player 10 to the HD.
but even then, with so many streaming interrruptions
( Real Media is notoriously buggy in buffering, even on
Cable modem) I still had to edit in QT after it was all done."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
If you have the RM clip locally, i.e. it's not streaming, then ffmpegX can convert it. I never had success with streaming content, although the decoder tries to read the rtsp stream from .ram files.
Not everyone feels ffmpegX is exactly easy, and Real support is even an additional install with some hassles (Helix libraries). But it can be done.
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 11:48 -
Converting or Joining MOV files
By theWallflower in forum Video ConversionReplies: 3Last Post: 8th Apr 2010, 07:00 -
Batch Converting MOV Files
By thomasj in forum LinuxReplies: 3Last Post: 25th Dec 2009, 14:50 -
mencoder converting realmedia files w/audio sync problems
By kruuth in forum Video ConversionReplies: 9Last Post: 26th Sep 2007, 15:34 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 16:46
