I an new to AutoGK. I am using version 2.27. In the past I have written a avisynth script to edit out the commercials of my avi file. Using this file as an input to tmpgenc has always worked fine. I would now like to use a similar procedure and use this avs file as an input to AutoGK. But AutoGK will not take an avs file as an input. What are other people doing to accompilsh this? I would really liek to avoid having to use VirtualDub to write out a modified avi file (without the commercials).
Steven
Well AutoGK is meant to be easy to use. Therefor it is not exactly flexible. What is wrong with using VirtualDub? That is what AutoGK would use anyway, you just need to calculate the bitrate, etc. yourself.
Well, I was hoping to use AutoGK to do the demuxing, encoding audio and video, and remuxing. I really did not want to do the steps separately. The only fancy thing I wanted to do was to edit out the commercials before I encoded everything. I guess AutoGK is not the right tool.
Steven
Autogk Virtualdub AVS question.
By meneedit in forum Video ConversionReplies: 0Last Post: 9th Feb 2012, 04:31 -
how do i take avs logo off avs video
By tnwolf35 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2010, 21:08 -
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 12:09 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59
