  1. I thought this player was region free out of the box but guess what it's not.
  2. It used to be, but later they changed it so you have to make it region free. To do so,:
    1. Press Setup on remote control to access the setup page
    2. Enter 9210 on the remote
    3. A secret menu will pop up
    4. Select 0 to 6 in region code (0 is region free)
    5. Press Setup on remote again to exit
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    https://www.videohelp.com/dvdhacks.php?dvdplayer=OPPO+OPDV971H+&hits=50&Search=Search
    Did you check the dvd player hacks section? Hmmmm....anyway there's the link. Search is your friend!
  4. Originally Posted by manono
    You are my idol.
  5. I'm happy to be your idol, but I can't in good conscience take the credit. You'll find that useful piece of information, as well as a whole lot more, in the first post of this very long thread:
    http://www.avsforum.com/avs-vb/showthread.php?p=4924650&&#post4924650
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    It is also the 971, NOT the 917, but everyone knows what you are talking about.
    Also, there is a huge thread over at avsforums concerning this player, with all of the recommended settings and such.
    Google is your Friend
