Hi
I'm a newbie with SVCD2DVD and had got into serius problems.
Here is my storry.
I started to test out SVCD2DVD 2 6RC on the following machines:
Win98: with AMD XP2700+ and 512MBR
Win2000 with Intel p4 3.200 GHz and 512 MBR
Win XPhome with AMD 64 3.400 Ghz and 1GBR
and all with great success.
So I decided to buy Vers 2.1 and now I got into troubles.
WinXP: At first I was not able to open the assets until I moved them to same logical drive where Vers. 2.1 was installed and it worked just fine.
Win98: I'm able to open and add assets but no assets are added not even with drag and drop.
Win2K: In the Menubar when pressing the Assets Action, Create your DVD, Shutdown/Options
and Help buttomI only got a thin shadow of the frames with no content which dissapear when I try to mark them.
I can drag and drop thes assets but it's useless when I'm not able to access the Create-buttom.
So the buttomline is: The free trial version works but genuin don't.
Is there some kind person who can help me out![]()
, thanx:
Ok. Lets try to nail these.
and Help buttomI only got a thin shadow of the frames with no content which dissapear when I try to mark them.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hi and thanx
On Win98: AVI and the testassets (DummymenuNTSC.mpg, DummymenuPal.mpg,
Splash.mpg.)
On XP: C:\D-drev på Maskine2\Film (didn't worked) but C:\Film (worked)
On Win2K: Can't download the demo, get an invalid archive mess. and only between 200kb and 1.3 mb are downloaded. Have tried on 3 machines now.
Splash.mpg.)
On Win2K: Can't download the demo, get an invalid archive mess. and only between 200kb and 1.3 mb are downloaded. Have tried on 3 machines now.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hi, thanx
Have downloaded the DEMO:
On Win2k : Just the same as origin.
Origin:
On Win98 : C:\film\ AVI and the testassets (DummymenuNTSC.mpg, DummymenuPal.mpg,
Splash.mpg.) don't add the assets.
Demo:
On Win98: SVCD2DVD.exe - Common Language Debugging Services:
Process-ID=0xfff5ec37 (-660425) , Thread-ID=oxfff344df (-834337)
but these 2 values change every time I try to start the Demo.
Have tested it with .Net-Framework 1.1 and 2.0
Technical Issue using two cameras and Premiere Elements
By VitalExpressions in forum Video Streaming DownloadingReplies: 1Last Post: 17th Feb 2010, 08:04 -
Who here knows their technical stuff inside and out???
By suomalainen in forum DVD & Blu-ray PlayersReplies: 7Last Post: 12th Dec 2009, 22:39 -
Software to view technical info of dvd video
By cengoh in forum Software PlayingReplies: 3Last Post: 28th Sep 2007, 03:59 -
technical question on center ch. of Dolby Digital
By dondeaida in forum AudioReplies: 5Last Post: 19th Aug 2007, 08:11 -
starting up technical forum website
By rikit in forum Off topicReplies: 5Last Post: 28th May 2007, 15:25
