Ive been using HDTV2MPEG2 for a while now, but im still getting audio sync problems. Seems to be random, some rips are fine, others are out of sync. I am careful to set the cut points BEFORE a show goes to commercial and AFTER it comes back, but still, not sure what the problem is.
Ive used other applications to remove the commercials, but they dont appear to handle transport streams, only the HD mpeg2 file. Apps like Videoredo or Pegasys Editor will edit just fine, but when I export or save, I get only the video (no audio). In fact, I have yet to find an application (many have been suggested) that will edit HD MPEG2 files and keep the AC3 audio intact.
I am using MyHD MDP-100 on Windows2000 SP4 - 1.8Ghz AMD - 768MB Ram.
