If i copy a DVD to my hard drive and i want to edit it then rewrite it to dvd what is the best way to do this?
What i would like to do is to convert it to DV-AVI ---> Edit (save as DV) ----> MPEG2 --------> DVD
so as to loose as little quality as possible, but how do i converd a DVD to DV-AVI?
virtualdubmpeg2
or use mpeg video wizard or tda for simplier editing directly from dvd vob files. -
The way you want to do it will involve re-encoding and therefor a loss of quality. Are you just looking to trim out parts or add parts, Then Baldrick's solution will work to edit although myself I would use VideReDo Plus.
OTOH if you want to edit out or change the soundtrack then you'll need to rip to the hard drive and go from there.
So basic question is what is your goal? -
I would use VirtualDub Mod for that, myself. You will need to add a DV codec to encode to DV. The Panasonic DV Codec works well for me. If you want to add permanent subtitles, look here: https://forum.videohelp.com/viewtopic.php?t=272736 For the creation of the subtitles, check our Subtitle forum for ideas.
Be advised you will have 2 re-encodes. You will lose some quality with each. First to DV and second back to MPEG-2. You can frameserve the output of VDM to an encoder like TMPGEnc to save hard drive space and some time. VDM can accept VOB files directly. Then you don't have to convert them to MPEG first. Keep your bitrates high and you should minimize the loss.
Good luck on this, and let us know if it works for you.
Yea i could try permenant subs, but i don't think they will give the results i want.
I want quite flashy txt -
To Do Subs cut and editing you can use MPEG video wizard. You could try it for free. That way you don't have to go back and forth between format and get all complicated.
I want to believe.... -
But i don't want subs, i want titles to come up.
I don't think just subs would be good enough
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 22:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 22:31 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 08:06 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34
