I have a SONY DVD403 cam corder. My girlfriend and I recently went out for the day and took some clips. When I transfered the footage to my PC I noted that one of the clips she had taken played SIDEWAYS, this is crazyWhen I asked her about it she said I put the cam corder on its side it should be ok like a still camers ( DUH !! ) Now what !?! I have tried several programmes but nothing plays it properly.
Is there a software programme that will allow me to rotate the movie ( like you can with stills in windows picture & fax viewer ) ? I very much want to sort this out as we cannot recreate the movies againIf I can find a programme to rotate it, presumably I can "save as" and then all will be well ie it will play as NORMAL ?
what is the video format? avi,mov?
and read https://forum.videohelp.com/viewtopic.php?t=292080&highlight=rotate+video -
AviSynth has the capability to rotate the video 90 degrees, then Virtualdub can preview the video and then create an .AVI clip. It will be considerably larger than your original MPEG file.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
virtualdub supports mpg, for mpeg2 use virtualdubmpeg2
virtualdub rotate guide, http://www.windowsmoviemakers.net/PapaJohn/71/Rotating_Cropping_Video.aspx
videos displaying upside down, sideways
By bj nick in forum EditingReplies: 3Last Post: 1st Jan 2011, 21:17 -
16:9 Video Plays as 4:3
By TheArtfulDodger in forum MediaReplies: 4Last Post: 13th Dec 2009, 11:59 -
video is sideways - how to flip it?
By lpmitch in forum EditingReplies: 6Last Post: 16th Apr 2009, 20:57 -
plays audio no video
By knothead in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Mar 2009, 10:45 -
Video plays like FF on playback...
By neomaine in forum Video ConversionReplies: 2Last Post: 10th Dec 2008, 10:55
I will try it
