i have an avi file that i am trying to encode using tmpgnc, but when it picks it up it doesn't pick up the audio......it uses ac3 for audio . i have the ac3 filter on my pc installed and the necessary codec, so how can i fix this problem.
AC3 Filter is a directshow filter. You would need to open the file via dshow for it to work, so crank the dshow priority in the VFAPI settings or install fccHandler's AC3 ACM codec.
Or optionally, you can open the .AVI in VirtualDubMpeg2, and save it out as an uncompressed .WAV file..
When you encode in Tmpgenc, simply use the .WAV as the audio source, rather than the .AVI's audio....
Good luck!!! -
Note that this version cannot decompress AC-3 audio.
If you need AC-3 support, try my AC-3 ACM Codec.
MKV Conversion Difficulty
By thatmantisguy in forum Video ConversionReplies: 6Last Post: 5th Mar 2010, 16:04 -
Sony HDD download difficulty
By doccah in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Jul 2008, 22:23 -
Difficulty Accessing Video Help
By usually_quiet in forum FeedbackReplies: 7Last Post: 14th Apr 2008, 17:11 -
having extreme difficulty downloading this video
By jimdagys in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2007, 03:09 -
Rare Decryption Difficulty
By Big C in forum DVD RippingReplies: 2Last Post: 8th Sep 2007, 10:24
