    Dec 2001
    United States Boise Idaho
    Ok I have been doing the old VCD discs for some time and had purchased a JVC mini dv Gr-D93U Camcorder. I just made my first home movie all with studio 9 and the play back quality was not as good as I had hoped it was some what blurred. Do I just need to tweek my settings or is this just the norm for this software? What is my best hopes on good quality play back on my dvd's? I have a fairly high end computer system so it should handle video editing just fine. Thanks alot Taz in Boise idaho
  2. VCD format itself is of low quality, i.e., low resolution and low bit rate.
    I do not know any home made VCD with high image quality. If you
    want to get better quality, try SVCD or DVD. It is significantly better
    than VCD.
    Dec 2001
    I am no longer making VCD'S I am making DVD'S and I feel the quality could be better.
    gateway Gt5028
    athlon 64X2 dual core 3800+
    250 gb Hd
    1 gb ddr2 pc3200
    dual layer dvd+/-rw
    dvd rom
    video card PNY 6600 pro PCIe 256mb
    sound card sound blaster live
    Studio 9
    Boston acustic digital speakers w/ subwoffer
    17" LCD
