I have just started to learn scripting with AVISynth. The docs claim you can use the directshowsource command to open several .vob files by chaining together with a "+" sign. I can not get this to work. Have tried countless examples from other guides. Could someone please paste a working script line with correct syntax for both chaining the vobs and appending the fps at the end. Thanks for your help.
Yep, load the Vobs into DGIndex, and then File->Save Project. That creates a D2V Project File which you can then use in your .avs:
LoadPlugin("C:\Path\To\DGDecode.dll")
MPEG2Source("C:\Path\To\Movie.d2v")
Once you get the DGMPGDec package (which includes DGIndex and the DGDecode.dll), be sure to read the DGDecodeManual.html, DGIndexManual.html, and the QuickStart.html. They explain the right way to do it.
Will Avisynth 'Directshowsource' Produce Reduced Quality in Frames Served?
By Chakra in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2011, 10:25 -
avisynth: directShowSource, ffVideoSource, avcSource -- speed
By adom in forum Video ConversionReplies: 8Last Post: 14th Jun 2011, 21:35 -
1920x1080 mov, avisynth directshowsource = 1440x1080?!?!
By duhmez in forum Video ConversionReplies: 5Last Post: 5th May 2011, 07:01 -
Avisynth Directshowsource Problem
By Robert Simandl in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 08:41 -
DirectShowSource() reliability problems for DV decoding in AviSynth().
By towtruck in forum Video ConversionReplies: 4Last Post: 28th May 2007, 10:43
