hi
when i insert a cd into the player
it tries to read ( loading ) but than i get a "no disc" massage
the cd's r original
and my player supports dvd ,cd ,mp3 ,cdwr ext...
pls help![]()
tenx
Results 1 to 13 of 13
Was it finalized?
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Oh sorry didn't see the part of it being an original disc. Please ignore my post.
Do DVDs play with no problems?
You might try a CD laser lens cleaner. (A DVD player uses different lasers for CDs as opposed to DVDs, if I remember correctly.) Also, which DVD player are you using, and are the CDs plain audio CDs (no extras, data tracks, etc.)?If cameras add ten pounds, why would people want to eat them? -
the cd's were plain audio ones
i didnt try to load an original dvd
the dvd player's label is elektra, i cant remember the specific model -
i apologize for my ignorance , but wont my player will have
some difficulty to read or to load the cd laser lans cleaner? -
rimi: If you have a CD laser lens cleaner around, go ahead and give it a try.
However, if you have to buy one, a DVD laser lens cleaner might work in this case. ^_^
To be sure, though, you should try a few regular DVDs and a handful of other audio CDs just to see if it isn't only rejecting those few discs.If cameras add ten pounds, why would people want to eat them?
Womble mpeg video editor I get "No disc or disc error"
By pumpkinslion in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2010, 20:32 -
"can't read disc, check disc" problem
By ttheb1 in forum Authoring (Blu-ray)Replies: 1Last Post: 13th Jun 2010, 07:34 -
Will my regular DVD player play a "blu-ray to DVD " disc ?
By htp367 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Oct 2008, 13:28 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08 -
"Unknown Disc" error for all DVDs - is my player dead?
By RosieP in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Nov 2007, 08:49
