  1. I recorded a couple of episodes of a tv show on dvd & my bro would like copies. can I do this with nero?
    Apr 2004
    Miskatonic U
    Yes.
    Read my blog here.
  3. Member steveryan's Avatar
    Jan 2003
    Manchester
    He's a liar and a murderer, and I say that with all due respect.
  4. All I get when I copy it is a image icon thats over 3 gigs. And when I try to burn this onto a dvd it just saves over the same file.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Then you aren't using Nero correctly. All you need to do is a disc copy.
    Either than, or use DVD Decrypter. ISO->Read, ISO->Write.
    Read my blog here.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd say you've got the Image Recorder selected in Nero instead of your burner
    If in doubt, Google it.
