Hi guys,
I am looking for a program to convert dvd to pocket pc.
Problem is I want to use wmv but i tried allready much different tools and the quality is good for 128 or 256 MB but the subpicture isn't sharp.
So who knows a program to convert DVD to POCKET PC wmv from 128 to 256 MB where you can select a sharp subtitle?
Thanx
Results 1 to 9 of 9
Search for VEMoDe , it cover's sony psp , apple ipod , palm , pocket pc , and three other's .
Http://vemode.corcodec.org .
Many setting's , allow's for additional support for other device's through xml script , and it's another freebie . -
Thank you but it's avi format and not dvd supported.
Maybe something else? 8) -
I use AutoGk (Auto Gordian Knot) on my AXim X5. It uses Xvid and takes a while to convert a file but it will normalize the audio and permanently overlay the subtitles if you desire. Give it a try.
You could use DVDD to extract a single vob file and then load that into WME and convert to wmv.
Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
I don't think it's possible to add subtitles to it?
Or is it? 8)
Sorry for my stupid questions but i found out that a good app for dvd to wmv pocket pc with good readable subs isn't out yet or somebody has allready made it but i don't know
No subtitles for WME. I guess you could hardcode them into the video. I don't know if DVDD does that..
Melde Melda Vessė
Getting DVD rips on to aaxa p2 pocket projector
By Duck in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2010, 13:32 -
safe few bucks from my pocket
By mrdin2005 in forum Video Streaming DownloadingReplies: 2Last Post: 20th Jul 2009, 05:26 -
Fujitsu Siemens Pocket LOOX
By mgowins in forum Video ConversionReplies: 2Last Post: 9th Jul 2009, 17:09 -
Movie player for Pocket PC??
By Cazz in forum Software PlayingReplies: 2Last Post: 2nd Jul 2009, 16:39 -
DVD / AVI / MP4 -> TO Pocket PC XviD using PocketDivXEncoder
By trueg in forum User guidesReplies: 0Last Post: 21st Apr 2008, 03:25
