  1. Hi,
    I'm trying to install Nero & but it says I cant until I install direct x 9.0b on my computer.
    I have tried going to microsoft.com even put on 9.0c but still nothing.
    I run windows XP.
    Anyone any ideas how I get this directx 9.0b and the best way to install it for making Nero 7 work??
    Thanks guys
    "you're damn it you don't you're damned if you do...catch 22"
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    9c is backwards compatible, try using the latest version of nero
    Feb 2004
    Australia
    You may want to check your xp update's .. and the version of dircetx9 already on the system .
    You dont mention having sp2 installed .
    There is an ms update regarding installer's that use script's that would fail for some unknown reason .
    Thank's to ms , I now have my expensive program's installing and running once more .
