When I open a new MPEG2 file, it closes the current one. I was wondering, is there a way to add to rather than replacing.
In virtualmod , you use a script to concat mpeg's one after the other so virtualmod read's them as a single file .
This should only be done where the mpeg's are of known matching type's in video format , audio , and of course anything related to vbr or cbr .
Under tool's .
Script editor .
If mpeg's are on C:\ , and name's are one , two , three , four , and five , then script is
c:\one.mpg
c:\two.mpg
c:\three.mpg
c:\four.mpg
c:\five.mpg
Save this script to save location as where the mpeg.s are ...
Name it mymovie , keep the name under 8 chararter's .
At the end of the name you must add the extension ".lst" , so name would be mymovies.lst .
Back in virtualmod , sellect open file , change the sellection to "all files" .
Browse to c:\ , sellect mymovie.lst file , and your done .
The only issue is concating file's of different :
Video , ie 352x288 , 704x576 , 320x240 , ect ... not a good idea .
Audio , different type's , mp2 , ac3 , vbr's , cbr's ... mixing these will cause audio resync issue's .
Framerate's , 23 vs 25 vs 29 ... again , not a good idea .
Of course virtualdub/mod dose not write mpeg format , for that you will need to re-transcode the video .
Under file , sellect frameserve ... all this video can then be sent to bbmpeg , which will encode into various mpeg format's , and has many advanced setting's .
How to use the framserver component , to bbmpeg :
https://forum.videohelp.com/viewtopic.php?t=270071 -
Thank you so much. Yes, the MPEG2 files are from the same DVD. I used DVD Shrink to extract a couple dozen 1-3 minute clips. When I open the folder using VDMod to convert to avi, it shows them as individual files. In the past I would have to open each file one at a time.
Problems joining multiple MPEG2 files together.
By MagicPockets in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2010, 09:47 -
Import multiple .VOB to VirtualDubMod
By ashwin.terminator in forum Newbie / General discussionsReplies: 0Last Post: 5th Apr 2009, 04:19 -
MPEG2 to Xvid with Virtualdubmod
By Cazz in forum EditingReplies: 25Last Post: 26th Feb 2008, 13:49 -
Aspect ratio change from DVB-T MPEG2 in VirtualDubMod
By josealberto1975 in forum Video ConversionReplies: 2Last Post: 23rd Dec 2007, 06:27 -
VirtualDubMod mpeg2 framerate
By _migz_ in forum Video ConversionReplies: 77Last Post: 16th Jun 2007, 12:16
