Hi. i'm a total noob at this and am hoping somebody here can help me. I tried searching and could not find anything that really seemed to help.
Ok. Here goes my question. I am in Chile have some PAL DVD's from europe. My DVD player at home is multiregional and supports PAL & NTSC, my TV will handle NTSC and PAL-M & PAL-N. When I play the DVD's they play, but are in black and white, as to be expected from the differences in the PAL flavors.
From what I have read the only difference between European PAL and PAL-N is the "color subcarrier frequency" is 4.434MHz for Europe and 3.58 for PAL-N. Anybody know how I can go about fixing these DVD's, hopefully easily.
DVD simply has PAL and NTSC, it doesn't have any of the variants (Some here argue it only has resolutions and framerates). Subcarrier information etc comes from the player. I don't believe this problem is related to the disc itself. It is different for VHS tapes, but for DVD, PAL is PAL is PAL, regardless of it's origins.
Read my blog here.
Thanks for the reply. But according to THIS site, Pal for most of the world is the almost same (the only exceptions affecting broadcasts). However there are two different varieties of PAL used South America (PAL-N and PAL-M). Pal-M (used in parts of Brazil) is PAL with NTSC framerates and sizes, while PAL-N has this diffferent color subcarrier.
.Originally Posted by the site linked to above
But, your rieght in that the site referrs mostly to VHS conversions. I guess it could be my DVD player then that can only output the european pal and my TV shows it in back and white. I'll look into it. Thanks again. -
This is a tough one
I'm the one saying frame rates and frame sizes are the only things that matters for DVD. They divide into
1. 525/59.94, 352 or 720 by 480 @ 29.97 or 23.976 fps
2. 625/50, 352 or 720 by 576 @ 25 fps
NTSC and PAL-M fit into #1
Euro PAL, PAL-N and "Combination N" fit into category #2 even though "Combination N" uses 3.58MHz subcarrier and "NTSC like" RF spacings for broadcast.
(Ref: http://icecube.wisc.edu/~dima/stuff/comp/vstandards.html)
The TV wants to see 3.58MHz subcarrier that is common to NTSC, PAL-M & PAL-N.Originally Posted by g00nter
I think the problem playing Euro PAL DVD is the player sets subacrrier to 4.43MHz instead of 3.58MHz. The TV is regionally multi-standard but can't seem to take 4.43MHz subcarrier. The DVD player can't produce PAL-N from a PAL disc.
This would all work if the TV could take YPbPr (component analog) which avoids the issue of PAL/NTSC subcarrier.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Pal to NTSC conversion ;o)
By StrobeLightEpileptic in forum Video ConversionReplies: 112Last Post: 30th Jun 2009, 18:59 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC to PAL-M RF conversion
By ptannjr in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 14:38
