It seems like this would be a common thing, but I can't ever find good info on a straightforward practice.
I have a PC with one of those nice little Hauppauge video capture cards. I run my DirecTV receiver right into it and reccord shows. It stores the video in MPEG2 format.
All I want to do is take one of these files (.mpg) and turn it into a DVD. That means converting it into .vob files. But I don't care about menus, or chapters, or any "overhead". I just want a simple process that will let me play them in a DVD player.
I don't want to degrade the video quality *at all*. It's my understanding that DVD's use MPEG 2 video anyway, so I don't even see why I should have to re-encode the video. Isn't there some way of converting a .mpg into the requisite .vob files and then just burn them to DVD?
I'd really appreciate feedback on this. Oh, BTW, I have to be able to do this in Mac OS X alone.
http://www.mediostream.com/products/index_neodvd.html
NeoDVD is a simple program that works every time, never crashes, and is the fastest program I have ever used. -
please post mac video stuff in our mac forum. moving you.
Easy.
Demux the mpg with ffmpegX or MPEG Streamclip (if you have the Quicktime MPEG2 component) or with Project X if there are data breaks in the stream, and then author as a DVD using Sizzle.Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
How can I take the clips from movies/DVD's and make them into videos ?
By jackbruce in forum EditingReplies: 5Last Post: 14th Nov 2011, 00:08 -
How to make DVD movies in high quality
By bell in forum Authoring (DVD)Replies: 11Last Post: 2nd Nov 2009, 09:42 -
How to make a DVD with different movies scenes?
By aplaza in forum Authoring (DVD)Replies: 3Last Post: 25th Aug 2007, 00:41 -
Editing self-owned dvd movies to make "clean versions" for my fam
By nef1l1m in forum EditingReplies: 5Last Post: 1st Aug 2007, 15:00 -
Why dont they make better movies?
By NICEBUD in forum Off topicReplies: 7Last Post: 10th Jul 2007, 16:39
