I am trying to upgrade my firmware for my NEC 3540A, I am trying to use Binflash and as far as I get is scan it in Command Prompt :
List of supported devices:
Device : H:
Vendor : _NEC
Model : DVD_RW ND-3540A
Firmware : 1.01
don't understand how to dump or write dump and save it
don't understand how to flash and write new flash that I downloaded.
I want to flash with 1.04 new firmware
Found out this should solve my +DL burning problems.
Could someone help me with this flashing stuff?
thanks
justmenow55@charter.net
I use Binflash with Windows Gui, it allows you to dump/save your old firmware and then flash the new one, all point and click from within Windows XP. (Win32 Gui)
http://binflash.cdfreaks.com/
Pick a firmware from here, I'm currently using Liggy's Bitsetting 1.04 with good results.
http://liggydee.cdfreaks.com/page/3540/
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 03:45 -
How to Upgrade firmware of Samsung MM-DG25?
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Feb 2011, 14:25 -
GoVideo DVR4100 Firmware Upgrade
By csupan in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2009, 21:03 -
Samsung BD-P1500 firmware upgrade
By D-Generate in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Mar 2009, 06:50 -
How to do firmware upgrade for a DVD Player
By Tiger_Lion in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2007, 00:33
