Results 1 to 16 of 16
    Mar 2006
    Canada
    Hi,
    I want to take a DVD of my wedding and re-edit it. The DVD was done by a pro and I don't have any of the original DV. These are the programs I have:
    IMovie
    toast 6
    ffmpegx
    I've aslo been checking out the program MyDVDedit, but after reading the tutorial I still have no idea what it really does. Any suggestions?
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    When you say you want to re-edit the dvd, what specifically do you mean?
    If the video wasn't to your satisfaction, shouldn't you take the
    product back to the company who made it and have them "fix it"?
    If a mechanic fixes your car, but it still makes "funny Noises"
    after you drive it off the shop lot, You can take it back have
    them fix the problem correctly.
    Or are you trying to do something something else....?
    Most videographers that I have run into at Mac Conventions seem
    like really nice guys and gals, who work very hard to please their
    customers. I'm sure if the video isn't up to your liking, they'd be
    happier to fix it, and gain a happier client than an upset one.
    That being said....
    The tools you have aren't sufficient.
    Depending on how the "pro" had the DVD "mastered", it might
    end up being more headache to fix the disc, and then re-burn
    it yourself to DVD-R, at less quality than the original.
    You are opening your self up to ripping the dvd off the disc,
    then demuxing the streams therein, re-editing the stream to your liking,
    then re-muxing back to mpeg stream and then you'd
    still have to RE-AUTHOR the disc.
    Far easier to take it back to the pro, but it's your call.
    If you wish to proceed, post back, we'll be happy to help.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Mar 2006
    Canada
    No the original is fine. I want to take some of the footage from this DVD and combine it with other DV footage and make a new DVD.
    Dec 2003
    Eugene, Oregon
    Drag the VIDEO_TS folder from the DVD to the Toast Video window. After cancelling the error message select the video that appears in the window and click the Export button. Save the video as a DV file. A 1-hour movie will require about 12 GB as a DV file, by the way. You can now import this DV video to iMovie (which makes a copy that will require an equal amount of HDD space). You now can edit in iMovie. Lastly you can use Toast 6 to encode, author and burn your new DVD from your edited iMovie.
    Unless you earlier received permission to reuse the video's content, you should ask the videographer for permission because the videographer owns the copyright.
  5. Member terryj's Avatar
    Fro,
    if he only wants a small protion of this,
    wouldn't be easier to Rip to the HD
    using MTR, and then using MPEGStreamclip,
    provided he's willing to buy the MPEG-2 codec,
    to clip what he wants, and then export to DV
    to patch together with his other DV Footage
    in iMovie?
    Or is there something else I'm missing...?
    I know its a trade off: Completely free vs. Pay,
    Having A LOT of HD space, vs. only a couple of GBs
    for the exported clip, etc.
    and yes, Fro is right, and you may not believe so,
    ( I've heard of a customer arguing with a videographer I met
    at a mac show recently about this) but while the wedding DAY
    is yours, the Wedding FOOTAGE is ™, ©, and ® the videographer.
    Which is why I made the suggestion of just going back
    to the vidoegrapher ITFP. Chance are they have/or can
    extract the clip you need and put to disc/HD for a small fee.
    *shrugs*
    Urban Mac User
    Mar 2006
    Canada
    terryj,
    What do you mean by buying the mpeg-2 codec?
    Dec 2003
    Eugene, Oregon
    terryj,
    I agree with you that it makes more sense to use MPEG Streamclip to extract the desired segments. My suggestion with using Toast is the least-to-learn method but not the best-to-use method. I don't think the DVD needs to be ripped because it probably isn't copy protected. If so, the video can be extracted directly from the DVD or the VIDEO_TS can probably be dragged to the hard drive.
    dylanb2cm, MPEG Streamclip is freeware but it requires Apple's QuickTime MPEG 2 playback component (that you can purchase for download from Apple's site for $19.95) in order to view the MPEG video from your DVD.
  8. Member terryj's Avatar
    Fro,
    I figured you were going for the "newbie/free/using his tools
    on hand" method, just making sure.
    Urban Mac User
    Mar 2006
    Canada
    thanks for the advice
    Mar 2006
    Canada
    Well better late then never. Fro, I imported the VIDEO_TS folder to the Toast video window. No error message came up. 2 video frames came up. When I selected the shorter one and hit export. A message came saying I need Toast with Jam. Something abouth the Dolby Digital AC-3 files. I got the same thing for the longer video. Am I doing something wrong?
  11. Member terryj's Avatar
    no. it is just telling you that it can't process the AC3
    audio track without the Jam add-on.
    At this point, you'll need to use my mention of MPEGStreamclip,
    and be sure to purchase ( as Fro stated)
    the Mpeg-2 component for Quicktime.
    it's cheaper than buying the Jam add on for Toast.
    Urban Mac User
    Mar 2006
    Canada
    I just installed the jam add on to my computer. I'm still getting the same error message saying that I need Jam for the doby digital files. What up?
  13. Member terryj's Avatar
    Jam may be looking for the AC3 codec when opening the audio?
    see here:
    Toast and AC3 or here
    go here to get the codec.
    Urban Mac User
    Mar 2006
    Canada
    If I buy a stand alone DVD recorder that has a firewire connection on it, could I put a DVD into it and hook my camcorder up to it and copy the disc back on to the camcorder wich would convert it back to DV?
  15. Member terryj's Avatar
    Most on the shelfs only allow Firewire IN, not out.
    The Higher Dollar Pioneer Series DOES allow it,
    we have discussed this in length here:
    DVD Recorders and input to Macs
    Urban Mac User
    Dec 2003
    Eugene, Oregon
    That only would work with the Pioneer 310, 320, 510 and 520. All other standalone DVD recorders do not export DV video via Firewire.
    I'm trying to figure out why you're having this difficulty. I have Toast 6 with Jam, selected a personally-burned DVD that had AC-3 audio and when I clicked "Export" the conversion to DV began without a hitch. Did you launch Jam after installing it? (It doesn't need to be open when using Toast. Are you using Toast Titanium 6.0.7 or later (I recommend 6.1.1)? It doesn't work with Toast 6 Lite.
    Still, there are lots of tools for exporting to MPEGs to DV.
    As for using your camcorder, if it can record via an S-video connection you could just connect the camcorder that way to any DVD player to copy a DV version to tape (or possibly even passthrough to iMovie without recording to tape).
