Results 1 to 9 of 9
  1. Thanks to a certain member on here, I'm addicted to ogame.org. Anyway, every now and then I get a dialer type thing popping up on my Norton. Sometimes it lets me delete it, sometimes it says I can't. When I can't I close everything, restart in safemode, turn off system restore and run a full scan. Nothing comes up...what's up with this? Is Norton deleting it anyway?
    SmileSmile
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    It's hard to say.
    Some viruses, trojans etc etc are designed to diable the AV program on the computer.
    This is a great place to visit:
    http://www.spywareinfo.com/
    If the trojan/virus/infection allows it that is....they are
    pretty sneaky. There must be something nasty floating around again because my Norton updated the anti-worm twice in one week.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    A lot of AV programs quarantine suspect items into a "virus vault", and my thoughts are that it possibly empties this on next boot.
    If in doubt, Google it.
    Mar 2006
    Australia
    Try spybot search and destroy that might get rid of it
  5. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Its likely in your cache. Try to clear your browser cache. Also make sure your not using Internet Exploiter.
  6. Originally Posted by Faustus
    Cool...and thanks for getting me addicted to this mofo!!
    SmileSmile
  7. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    No problem. I'm only playing in Uni12 these days. Things in 8 got a little to agressive for my liking.
    Feb 2004
    Australia
    Norton's is over rated , considering I used to use the pro edition .
    Avg antivirus not only beats norton's , but will remove them should they end up in the restore point's .
    Apart from hiding in the internet's cache folder , and temp , check your program file's folder as well .
    Some dialer's have been known to have there own install folder's , and the odd one or two can end up in the windows folder as well .
    Next time , go to start , type the word Msconfig , click ok ... go to startup tab .
    Look carefully at everything that is set to startup with the pc .
    If anything look's suspicious , uncheck it , hit apply , then ok , and pc restart's .
    If after all that , it work's , then you should remove the line from that startup area .
    Go to start , run , type the word Regedit ... here you will see about 5 main groups to the left in a two paned window for regedit .
    Forget the first item and last item ... so 3 remain .
    Do this for each item , one at a time ..
    Click on the plus on first main item .
    Click the plus on software .
    Click the plus on microsoft .
    Click the plus on windows .
    Click the plus on Current version .
    Now go down to those Run's
    Check them out for that line that appeared in the msconfig startup group .
    Left click item to highlight it , the right click and choose delete .
    Repeat this for each main group
    The main group's that should be checked and this applied to are :
    HKEY_CURRENT_USER
    HKEY_LOCAL_MACHINE
    HKEY_USERS
    Watch this last one , it has several group's in it , and you need to check them all for than line in the Run section's .
    Once done , close regedit , and it should nolonger bother you .
  9. Member isogonic's Avatar
    Jan 2003
    @localhost
    if all that fails do a online scan or two:
    BitDefender Free Online Virus Scan
    http://www.bitdefender.com/scan/licence.php
    check AutoClean under Scan Options.
    Panda ActiveScan
    http://www.pandasoftware.com/products/activescan?NRMODE=Published&NRORIGINALURL=%2fact...ACHEHINT=Guest
    Kaspersky virus scanner
    http://www.kaspersky.com/virusscanner
    Housecall at TrendMicro
    http://housecall.trendmicro.com/housecall/start_corp.asp
    check Auto Clean.
    F-Secure virus scanner
    http://support.f-secure.com/enu/home/ols.shtml
    eTrust Antivirus Web Scanner
    http://www3.ca.com/securityadvisor/virusinfo/scan.aspx
