  1. I'm using DVDRemake to merge 2 small DVDs onto 1 DVD.
    I want a main menu at the start of the DVD so I can choose which one to access.
    I tried the guides on the DVDRemake site about making a custom menu. I have a background image already, I want 2 buttons (each to the different DVDs) to be selectable and "highlightable". But I can't find an app that design a menu with buttons AND then convert it to VOBs in order to be able to import into DVDRemake.
    Anyone done this before? A main title menu with two selectable "highlightable" buttons?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    AFAIK I think you can just make your menu in any other authoring program (ie. TMPGEnc DVD Author) and then import the VIDEO_TS.VOB or the VTS_0n_0.VOB file(s) you require.
    If in doubt, Google it.
