I am using DVD Santa to create Video DVD's.
I am converting mpeg & avi files, and it seems to work ok, but i have noticed a sync problem.
Is there anyway of solving this? or does anyone know of any software that does the same job but without the sync problem?
Mark
ConvertXtoDVD has less of a sync problem than most, but the only way to make sure you don't have these problems at all is to learn how to use the correct tools for each job. This means converting video seperately to audio, and authoring correctly to produce a finished DVD. One-click-wonders like WinAVI and DVD Santa are lowest common denominator applications that try to do all things, and end up doing none of them very well, if at all.
Read my blog here.
Yep, another vote for convertxtodvd (or its freeware predecessor, divxtodvd) here. It depends a lot on your sources though. The "typical" downloaded clips have great things like VBR MP3 in them which often causes problems, no matter how good the software is.
If in doubt, Google it. -
I recommend DELETED , create DVD from AVI, MPEG, WMV, RM, RMVB, MOV, DivX, Xvid, VOB, 3GP, MP4 files and easy to use, create great DVD video disc with DVD menu.
I download it from DELETED, just download to have a try.
How Kris Kringle Became Santa
By MOVIEGEEK in forum Off topicReplies: 0Last Post: 18th Dec 2009, 17:59 -
Making a copy with DVD santa
By 1234567 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jul 2008, 03:19 -
Error message with DVD Santa
By poppy56 in forum Newbie / General discussionsReplies: 8Last Post: 1st Feb 2008, 18:00 -
Santa has arrived on site.
By gll99 in forum FeedbackReplies: 5Last Post: 6th Jan 2008, 18:27 -
dvd santa and vista
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 13th Oct 2007, 15:31
