Thanks for the previous replies to my earlier post.
But am I the only one who has serious problems making analogue video capture programs work?
I have P4, ATI Theatre Pro, 2 Gigs ram, 400 gigs HD.
I have yet to find an all in one program that actually works on my setup.
Pinnacle 9.3 worked for a while then decided it wouldn't any more. No other version of Studio will work on my machine.
I d/loaded Ulead Studio 9 Trial. It won't capture analogue. I can sometimes get the video to show, but then I get a message saying there is no signal.
Should I be looking somewhere else for the problem, or is it common?
I guess I'm wondering why you're not using the capture program that came with the card? Just to be sure to use the latest version of the program from the companies website. That should work 99% of the time.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Originally Posted by yoda313
Simple VHS Capture Questions
By mostly_useless in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2011, 16:00 -
HD Video Capture questions
By lost123 in forum Capturing and VCRReplies: 8Last Post: 29th Jun 2011, 21:02 -
mpeg2 50mbps capture questions
By the1selecta in forum Capturing and VCRReplies: 13Last Post: 30th Oct 2010, 21:22 -
Capture Card Questions
By Veldimare in forum Capturing and VCRReplies: 8Last Post: 18th May 2010, 14:14 -
HD Capture questions w/ Premiere pro
By miamibluemoon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 27th Feb 2008, 01:38
