I didn't know if this goes in Computer or Mac so if its wrong, you can move.
First off, I'm not using Airport. I am using a USB adapter to connect wirelessly and am using WirelessUtilityUSB to connect. The problem I'm having is that everytime I want to connect, I have to type in the key. Is there a way for it to remember it so I don't have to keep typing it in everytme?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
a real issue... try this
enter the key with a $ prepended to it and using the hex
see http://www.practicallynetworked.com/downloads/Other/tb-027.pdf for maybe more info"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 06:45 -
Best Wireless Utility that can be used with any wireless card
By mol3000 in forum ComputerReplies: 4Last Post: 7th Jul 2009, 13:29 -
Wireless: Is MAC Address Filtering Enough?
By p_l in forum ComputerReplies: 8Last Post: 2nd Jun 2009, 01:41 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
