Results 1 to 12 of 12
    Jan 2006
    New Zealand
    this is actualy a 2 part question, any answers welcomed.
    1). How do I extract a AAC audio stream from an avi. the tool needs to be commandline
    2). How do i convert AAC to lame mp3, again the tool must be commandline
    thanks very much in advanced
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Besweet can get the audio out of an avi and it has a command line or gui interface. Unfortunately it doesn't look like it supports aac. There may be an add on for it though. Also you might try doing a net search for aac to mp3. I think there's a program that converts pretty much any audio source to mp3 like besweet but I don't think its command line (dbpoweramp???).
    Jan 2006
    New Zealand
    *sigh*, oh well, guess it would have to do..
    thanks though!
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Good luck.
    Dec 2004
    Australia
    mplayer can decode to wav or demux. Well if you output to wav, lame.exe can convert directly. Should also be possible to pipe between the two.
    mencoder can convert the audio directly, however it can't do audio only. ffmpeg can, but it doesn't appear to support aac in avi.
    Jan 2006
    New Zealand
    mencoder does not support AAC, thats the whole problem i have lol
    Dec 2004
    Australia
    mencoder does support aac, including from an avi. I just did a test encode to make 100% sure.
    Jan 2006
    New Zealand
    hmm, i have here a wmv3 vid codec + aac audio avi, it wont convert, it just skips every frame.
    but as soon as i tried -oac copy, it worked.
    what commands u use?
    thanks
    Dec 2004
    Australia
    I used -ovc copy -oac mp3lame. What is the date of the mencoder build are you using? I was using a 06-03-23 build.
    Feb 2004
    Australia
    Mediacoder dose support the conversion , but the program can be a pain .. need's more work .
    For mp4's , use mp4ui to strip audio out to seperate file , the mediacoder to convert aac to wav / mp3
    Jan 2006
    New Zealand
    that must be the reason, my is the one that came with mpayerpre7 something something.
    can you tell me where you got that version?
    also MEncoder support wmv codecs right?
    Dec 2004
    Australia
    Yep, some via libavcodec, others via MS's DMO decoders.
    I compiled it myself.
    You can find my compiles here: http://ffdshow.faireal.net/mirror/mplayer/
    Main page is: http://celticdruid.no-ip.com/xvid/
    If it is still skipping frames, try -noskip. It actually does something in the 27th build. The skipping frames has nothing to do with aac though.
