If the RAMDAC is converting RGB samples at 400MHz then the analog output will be the same 400 MHz. Unless of course the card has poor analog circuitry which degrades the RAMDAC's output.Originally Posted by edDV
Ignoring vertical and horizontal retrace, front and back porch, etc., you can roughly estimate the bandwidth by multiplying the width, height, and refresh rate. So at a minimum you get 267 MHz for a 2048x1536x85 display (adding in the retrace, porch, etc ups that by about 30 percent). You can argue about exactly what "far beyond" means, but computer displays can require more than twice the bandwidth of any HDTV.
Results 31 to 33 of 33
I'm failing to understand your point.Originally Posted by jagabo
RAMDAC is about Digital to Analog conversion from the Display card's frame buffer over analog RGB to the monitor.
Are you trying to compare this to 1080i Y,Pb,Pr which is an analog video standard?
I agree that sending the desktop out over a 1920x1080i Y,Pb,Pr video connection is lower bandwidth than a 1920x1200 WUXGA RGB connection but the WUXGA connection can go 6 feet whereas the Y,Pb,Pr connection can be linked to the other side of the world by various transmission methods.
These are apples and oranges comparisons.
If we are talking about DVI-D, the output frame buffer is clocked out as digital RGB to the monitor at near identical bandwidth for 1920x1080i and WUXGA 1920x1200.
Dual link WQXGA (2560 × 1600) is only 7% wider than 1080p so where you you get "far beyond". To me all this is in the same "ballpark". -
I've tried the above instructions but I cant get the Video Mode button to appear. I have a ATI Radeon 9800 Pro and am running Windows XP SP1. The driver I'm using is 6.14.1.6292. Can you tell what I'm doing wrong? Thanks.Originally Posted by jagabo
Maximum 16:9 resolution for DVD?
By Paul Hetherington in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2012, 05:29 -
The wonders of miniaturization.... NOT!
By MeDiCo_BrUjO in forum Off topicReplies: 13Last Post: 27th Aug 2009, 14:50 -
AVI Output Resolution?
By rowlers in forum DVD RippingReplies: 13Last Post: 31st Oct 2007, 13:14 -
Is there a maximum resolution or size for jpgs imported into Vegas 7?
By nzo in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 21:18 -
Video output not at the resolution it says it is
By tiny-e in forum ffmpegX general discussionReplies: 8Last Post: 27th Sep 2007, 19:32
