  1. I have a Video_TS folder im trying to burn, I used Nero Express DVD-Video Files to do this and the screen looked like below. When I burned this and put in my standalone it says loading and nothing happens? Did I miss a step
    http://img.photobucket.com/albums/v193/Torontohound2004/ProblemScreen1.jpg
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sounds to me like the DVD structure is all fooked up.
    I'll go with the benefit of the doubt and presume you used VOBBLanker (or similar) on this ?
    Irregardless, if menus are not important, you should be able to reauthor movie only in DVDShrink or even IFOEdit ( http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit ). You could always then import this into something like TMPGEnc DVD Author and create your own menu(s).
    Or try something like PGCEdit or DVDRemake, which should be able to give you a better idea of the order in which it is trying to navigate the DVD at present.
    If in doubt, Google it.
