I want an AGP video card that is passively cooled for use in a PVR.
I am having a hard time determining and or finding a card that is passively cooled, that information just isn't always available.
I'm wondering if anyone knows of a place to look that will give me that kind of info.
Newegg seems to be the only vendor that does this, but they seem to be getting out of the AGP business.
Anysuggestions?
Results 1 to 14 of 14
Robert
http://www.Money-Guides.com/ -
you mean a agp card that dosnt use a fan right? i dont think that sould be hard to find, just look for a older (and less expensive) agp card.
http://www.directron.com/passively.html -
check any of these out (you dont need to get an older model at all)
Sapphire Radeon X800 GTO Ultimate (uses a heat pipe - no fan)
Asus A8R-MVP (made for htpc)
X800XT AIW
X1900 All in Wonder
gigabyte GV-RX16T256V-RH (perfect for htpc)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
AGP is being outmoded by PCI-E. I use a Sapphire Radeon 9550 in my media computer. It uses the ATI chip set. Runs fairly cool with just a small heat sink. It has a VGA, S-Video and DVI output.
It's not a high end card, though, but works fine driving a ATI DVI to Component adapter for my video projector. It runs about $48 at Newegg:
http://www.newegg.com/Product/Product.asp?Item=N82E16814102534 -
If you will be recording HD and using an HDMI input on your tv, you might want to spend some time and money looking into this. The cheaper fanless cards probably will cause you problems in that sort of setup.
Almost EVERY video card nowadays except very old ones are actively cooled. If you can't stand the noise, you can always buy a Zalman refit heatsink and apply that to your video card.
see list above (and that is not all) - there are many many models that are passive cooled ..
- this appears to be PCIEOriginally Posted by BJ_M
- this appears to be a MotherboardOriginally Posted by BJ_M
- Alas all I'm looking for is an AGP card (not tuner) I'm replacing an AIW because of reliability problems with the ATI choice in the Guide Plus TV Guide. For a PVR you really want to "set it and forget it". But ATI Guide Plus system is not reliable. The last staw was its inaccessability over the last three weeks. And ATI's total lack of concern. After submitting a support tickect I could only find out if it worked by trying to download new listings everyday till the download worked! I'm switching to a haupage Wintv/Beyond tv solution.Originally Posted by BJ_M
- see aboveOriginally Posted by BJ_M
- this apppears to be PCIEOriginally Posted by BJ_M
I'm stuffing all this into a shuttle, I have 1 PCI and 1 AGP slot, so space is a concern. It looks like the 9550 is the best I can find.
thanksRobert
Geforce FX 5900 XT can be run with no fan and just a heat sink .. you can buy them this way also ...
sorry about the list above -- i got that list from a htpc site , and didnt check it"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
NP!
Finding them is the hard part! I've found 5200, 6200, 7000, 9550, and 9250. I don't know which is the better chip. Most vendors don't tell you if it's fanless and may or may not show a picture and then they may not show the actual picture.
I just wish I knew how the cards I did find compare as far as performance.
ThanksRobert
I'd go with one of the fanless nVidia 6200 series from Newegg.com. The 6200s only have a 64-bit memory bus, but do have MPEG hardware acceleration, support HDTV, and are widely supported by any HTPC frontend you'd want to use. They're also only about $50 (a few even have rebates making them much cheaper).
Just make sure you stay away from the low profile models, unless you actually have a slim profile case requiring one. They're not the most powerful card there is, but they're very popular with HTPC enthusiasts.theHTPC.net
Find a cure for cancer by folding proteins! Join the Team 32 Folding@Home project (#3 worldwide!). Check us out here -
Just go though Newegg.com from cheapest up and pick one with no fan.
There are only a couple of cards announced and not yet shipping that truely support HDMI+HDCP. Better waith for that.Originally Posted by thinger62
If HD MPeg2_TS playback is needed better to stick to ATI-9550 up and upper NVidea but those all have fans. -
Performance for what beyond MPeg2 hardware playback assist?Originally Posted by rhendrix9
get a fanless 6200 or 6600 from newegg.com best service and selection around.
Where can I find a Vista driver for my Dynex sound card?
By Obamargarine in forum ComputerReplies: 7Last Post: 5th Mar 2009, 07:26 -
Trying to find Capture Card - w/ Component input
By tS_veXed in forum Capturing and VCRReplies: 63Last Post: 21st Nov 2008, 08:08 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Help install my USB PCI card Windows 98SE,have driver can't find hardware
By bnbhoha in forum ComputerReplies: 6Last Post: 13th Feb 2008, 13:58 -
trying to find the best capture card!!!!
By owen_o_we in forum Capturing and VCRReplies: 13Last Post: 4th Sep 2007, 23:39
