You are running a different version to me - I have 1.2.4, yours says 1.2.8. Your version has at least one bug, just from looking at it - it shows PAL resolution without the PAL box being checked.
Change the Destination Round To figure to at least 2 or 4, and preferably 16 and you will get the correct destination aspect ratio calculated. 2 or 4 will get you closest to the original.
There was a post recently, by Adam, I believe, that had a good run down of the FitCD controls. I couldn't locate it the other day, but I remember reading it. Probably worth hunting for to get a better feel for what these numbers mean.
OK, this isn't the post I was thinking of, but it does have some good reading. I have linked you in part way through, but the whole post is worth a browse.
https://forum.videohelp.com/viewtopic.php?p=1439484#1439484
Results 61 to 64 of 64
Read my blog here.
thanks. I changed it and got the commands I supposed should be there. Thanks and I will have a go at the whole post you linked here. thanks a lot !
It was FulciLives, guns1inger:
https://forum.videohelp.com/viewtopic.php?p=1487285#1487285
Tweaking VHS captures
By Cherbette in forum RestorationReplies: 165Last Post: 11th Oct 2011, 09:37 -
Best Video Converted Especially for DVDs
By rimmi2002 in forum Video ConversionReplies: 12Last Post: 11th Sep 2010, 18:57 -
Converted video has no audio
By franks65 in forum ffmpegX general discussionReplies: 5Last Post: 2nd Sep 2008, 08:43 -
Tweaking mencoder options
By acid_burn in forum DVD RippingReplies: 3Last Post: 27th May 2008, 08:59 -
Video Configuration tweaking...
By NHRaider in forum Media Center PC / MediaCentersReplies: 19Last Post: 15th Jul 2007, 14:16
