Does anyone know where i can download a free dvd burning program?
I recently converted a AVI file to dvd now im left with a VIDEO_TS folder with VOB, BUP & IFO files in them.
thanks
ps. I might be able to get hold of nero 6, will that work?
Look in 'Tools' to the left, under 'Burn' for freeware burning tools. But I would use ImgTools since you already have the VIDEO_TS folder. It will convert the folder to a image file and burn it with fairly high compatibility. Generally higher than Nero. But there are other freeware buring tools available there also.
Dvddecrypter can burn an iso , though I have seen it connected to nero api , and xp's default .
Use folder2iso to create the iso image first .
Also , Ghostburn , a free tool I picked up at www.downloads.com , hiding there .
It will only burn 4.3gig project's , either iso or from folder .
I post a guide on that on how to use it correctly ... it's got some habit's . -
I used ImgTool & DVD Decrypter and they worked perfectly, I was looking for a way to do this for months now so thanks a lot.
One last thing i only tried a clip that was 1 min long (69MB ISO File) but underneath the disk it looked like 1/3 of the DVD was burned. Doesnt it matter it being that much or am i just worrying over nothing?
Video CD/DVD Authoring Burning program Recommendation
By illyad in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 09:05 -
dvd burning/convert program which burns both 4:3 and 16:9 for single movie
By vampelle in forum DVD RippingReplies: 7Last Post: 20th Sep 2010, 03:50 -
Free program for Burning extracted DVD files to disc?
By lglrgl in forum Authoring (DVD)Replies: 1Last Post: 25th Dec 2007, 11:21 -
Best video file to DVD burning program? Any help greatly appreciated!
By Bathouse in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 13:57 -
Whats the best DVD burning program out there?
By Tielurr in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 18:21
