Results 1 to 12 of 12
  1. Banned
    Aug 2002
    beautiful
    Post BSoD screens here, lets have some laugh
    (blue screen of death - as originally referred to windows' crash screen)
    Here is a mighty linux's bsod i've found:
  2. Member valvehead's Avatar
    Mar 2006
    This was the screen my friend and I got when putting together a system from old parts. There is nothing like beginning a fresh install of XP, waiting 40 minutes for all the files to copy and then restarting to end up at this screen. We tried all sorts of bios settings to no avail. I thought for sure that the hard drive was shot, but it turned out to be incompatible memory.
    This is why I'm glad I spent time researching and buying new warrantied parts for my custom PC. I've never had a BSOD or automatic restart. Even program crashes are very rare.
  3. Member Conquest10's Avatar
    Chicago, IL
    ^ I got the same screen when I tried tp just upgrade from ME to XP. Full install gave me nothing.
    His name was MackemX
    IRC_NOT_LESS_OR_EQUAL is a RAM issue most of the time. Or a problem with the motherboard or CPU communicating with the RAM. Or heat. Or all of the above.
  5. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Actually. Usually if windows is installed already and it suddenly comes up its a Driver issue. If reinstalling from scratch doesn't fix it THEN its likely a RAM issue.
  6. Banned
    Aug 2002
    beautiful
    everyone usually point to faulty ram in such cases, but in my experience it was always the heat or overclocked ram.
    I cant tell you how much time i have spent trying to figure it out with one of my old laptops (acer tm 312t). I changed rams, run memtest on them, they were all perfect. yet when it was running it always gave me that irq_not_less... crap and crashed after an hour two or more.
    Finally i tested the laptop opened up (literally - all components on my table, without case) and it was running for a week without a problem. It as the heat inside the laptop's case, not the faulty ram itself.
    Another common problem is overclocking FSB (and ram) when using cheap ram sticks. Same errors are bound to happen.
    So in my opinion 9 out of 10 cases is not the faulty ram piece itself, i am sure they dont die as often as urban myth would like you to believe.
    I never meant that the RAM was bad, but more that it was hot (rather than CPU), or needed heat spreaders, or was not in the slot correctly, etc. I don't think RAM dies that often either.
  8. Banned
    Aug 2002
    beautiful
    Yes I agree completely.
    Come to think of that - in 10 years and probly hundreds of different machines I had only 1 case of bad ram stick - and today im not so sure was it really bad piece of ram, as i dont think i knew 9-10 years ago about i.e. memtest...
    just to keep it with the subject:
  9. Banned
    Aug 2002
    beautiful
    and a more recent BSOD at RSA
    Feb 13, 2006
    ...Perhaps the most odd thing of the evening was when I found a Blue Screen of Death prominently displayed on a vendor system, and realized I was the only person who seemed to realize that it was a bad thing.
    LOL!!!
    (whole story here)
  10. There is a linux screensaver that will display all sorts of BSODs, I don't have it anymore though
  11. Originally Posted by lordsmurf
    yea, it can be ram OR heat for sure, i got the same message once when i had a faulty stick of ram......and again at another point when my processor fan started dying.....
    and just located this......
    http://www.sysinternals.com/Utilities/BlueScreen.html
