The DV only captuer up to 4gb then split into another file, is there any setting that stops it from doing that?
maybe because of the fat32 4gb limit. or do you have ntfs harddrive partitions?
it's NTFS already. DMF captures it with no problem at all, but VS7 seperates the files in to 4gb segments
Either a setting or you need to upgrade. Current version is 9.Originally Posted by fossil
ULead VS made massive improvements between 7 and 8. -
I've been using Ulead VS7se with Canopus-110 in recording tv shows. A recorded 30-minute tv show comes out to one chunk of 6.5gb avi file. An hour of recording turns out about 13gb, 25gb avi for a 2-hr movie and VS7se never split them into smaller files. I checked my settings and can't find any that indicates limiting the saved avi to 4gb. I just want to say that in my experience Ulead VS7se (at least my copy) does not split avi file larger than 4gb.
I mentioned that both DMF3 and Nerovision capture the video just fine. Both are capable to produce file size larger than 10GB in 1 single avi file.
Only VS7 splits the files, so it's kinda weird -
the problem remain unsolved. All my drives are formated NTFS, but the capture program refuse to work with files larger than 4gb, what gives.
Size of Capture file
By gasport in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2009, 16:46 -
Limited capture success with Pinnacle MovieBox Plus 510-USB device
By ccooper in forum Capturing and VCRReplies: 4Last Post: 17th Jul 2009, 12:52 -
Best app for HD-DVD to mkv conversion? With resulting file size around 4gb
By AndyD in forum Blu-ray RippingReplies: 1Last Post: 7th Apr 2009, 08:46 -
No sound on ULEAD Video Capture
By bagshot48 in forum Newbie / General discussionsReplies: 8Last Post: 17th Oct 2008, 11:18 -
Ulead DVD Workshop 2 CRASHING with 4GB MPG title
By steve8443 in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2007, 02:07
