I have been using Premiere to edit my videos for DVD. The sample rate has been set at 32KHz because I never quite figured out how to set the rate to 48KHz and have it stay there. Now I have a new audio capture devive that captures at a minimum of 48KHz. Before whenever my sample rates were different I would have audio problems.
!. How can I set my sample rate in Premiere to 48Khz and have it stay there.
2. This device is 24 bit. Does iot matter since Premiere is only 16 bit.
The device is a PreSonus Firebox and I'm using it to capture audio out of a Mackie mixer
What does this post have to do with Web graphics??
Anyways, here we go:
When you start a project, an you want to output to DVD you should always pick NTSC DV/48Khz audio..
Regardless of your original samplerate footage, Premiere should upsample to 48Khz..It will try to conform to your current project setting..
Is this from a DV camera, capture device, or tuner card??The sample rate has been set at 32KHz because I never quite figured out how to set the rate to 48KHz
Are you setting your project for 32Khz?
I'm confused...
I don't see why you should..Audio gets rendered out to project settings..Plus, it gets conformed immediately after capture..Before whenever my sample rates were different I would have audio problems.
Help with building a video editing workstation using adobe premiere pro C5
By shawn grimmer in forum Newbie / General discussionsReplies: 2Last Post: 7th Oct 2010, 14:00 -
Adobe Premiere Pro CS5 Editing Effects?
By Napy666 in forum EditingReplies: 1Last Post: 20th Aug 2010, 19:43 -
AVCHD EDITING IN Adobe Premiere CS4
By Don Man in forum EditingReplies: 10Last Post: 4th Jun 2010, 16:41 -
Adobe Premiere and editing of long movies...
By arminio in forum EditingReplies: 6Last Post: 25th Feb 2008, 19:07 -
Editing and exporting already compressed video in Adobe Premiere
By Rocky88 in forum EditingReplies: 4Last Post: 31st Jul 2007, 09:52
